gear question
heres a question for the pro 4 alliance guys here what gear would you run for wenatchee,and merridian......new to tese cars so any info would help
Hector,I believe you would run the same gear at Stateline,Wenatchee,Meridian...i dont know about a LM4 type of car,but a common gear for Stateline is a 2.14/3.27 for a 6.99 final. I guess the big question would be what rearend do you have..a QC? how many RPM's are you trying to turn?
www.raceidaho.com
well i have a 9 inch in it now ....would like a 8 inch or a qc if ya know where thiers one at
would like to turn around 8000 to 8200
I have a Speedway Enginering mini QC for sale, with 2 races and dyno time for sale
Currently it is set up as a 3 link with conventional coils, steel tubes, aluminium full spool,gun drilled axles, 10'' custom rotors from Coleman, and our caliper brackets with Ford Escort calipers. 2 sets of change gears + change pan
$2500.00
8.8
Hector, I have an 8.8 with 31 spline axles, "c" clip eliminators, spool,
4:11 gears ready to go,over by Tacoma. 360-458-3117. $1000.oo.good deal
