dirt late model team for sale
GRT # 1 over rail new gw shocks, new double pass wide core radiator, new lowers, howl ball joints, new sweet steering rack, Teflon lined hems on the tie rods, carbon fiber drive shaft, new dtc rotors and pads, new coated frankland rear end with edm, bearing bird cages, atl fuel cell with aluminum case, bolt in under rail bars added, full containment seat, magnesium brinn transmission, new Peterson rotor 5 stage dry sump pump and tank. Light weight lines, two msd set up new power steering krc pump ,sweet flat steering wheel, ful l containment seat
GRT #2 under rail, new gw shocks, new coated rear end with edm new bearing bird cages, new rods all the way around with the Teflon lined hems, new aluminum j bar, new carbon fiber drive shaft, new pro series brinn transmission new dry sump pump, new power steering krc pump, new upper and lowers and spindles, new body, bloomquist seat, sweet flat steering wheel, two msd boxes, new dtc rotors and pads , sweet flat steering wheel,
Appx 30 wheels and about 60 tires a lot of new tires
Two used quick change rears
Parts spindles , j bar, door bar, tie rods,4 bars, lowers, steering rack, radiators, bird cages, drive shafts ,shocks, starters, wires, and a lot of miss ?
Motor # 1 438 sb2 heads and intake manley billet rods, calies crank shafts, jessl lifters, je pistons, fresh brodix aluminum block, stealth carburetor, beyea try y headers
Motor # 2 435 13 deg heads and intake , dyers top billet rods, calies crank shafts, jessl lifters, je pistons, dart aluminum block, stealth carburetor, beyea try y headers fresh
motor #3 top of the line steel head 500 laps
new 1050 holly hp
f beyea try y headers new 23* two sets of 13-15-16-18 one set of sb2 $1300
springs appx 40
race tools grooving irons
, impacts,Buffers, jack stands, mats two race jacks, shock tools, 16 volt chargers,
new pit cart
5 gal vp tire prep
Gears appx 18
New light weight dwb grt powder coated black, fuel cell, gauges c---pit, deck, and roof
Truck and trailer go to racing junk add # 2076246 for pics and more info
or call 865 207 0035 thanks $160000
