panhard bar help on swingarm car
gonna switch from straight bar behind rearend to j-bar on a pinion mount. how do i figure out which j-bar to buy? how do i know how much bend i need? length? dirt mod w/ 9" rear. swingarm both sides. any help would be appreciated
We did this also. Look at Wehr Machine and Racing products webpage. We called them and talked and took some measurements off our car and looked at others already setup with jbar. Wehr has many different bars or can custom make one. This best part is his length adjuster as you do not have to remove it to set or change length. Make sure the bar does not have too much arch in it as it may hit pullbar as car moves. Probably not so much chance with swingarm as 4 link.
John
