Results 1 to 7 of 7
Thread: Lift Bar
    Aug 2009
    24
    Default Lift Bar
    A lot of talk about a lift bar but has anyone one actually run one on a mod? What shock are you using?
    lots of people run them on mods. Hughes chassis's use mostly lift arms. I know some skyrockets and grt's do also. Its pretty common really. As far as what shock/spring combo, i cant really help you there.
    Aug 2009
    24
    We run a GRT and are wanting to try one! I was just wondering if anyone has had any experience with it whats the pro's and con's?
    I dont know from experience, but first hand from a buddy that drives. He is a throttle smasher and said it really really hooked up for him in the slick. He didnt have to ease into the gas as much, could pretty much just mash it and go. Said it didnt seam to work as good in the tack as a pull bar, but when it got marginal or slick, it really helped him hook up.
    Call GRT they can hook you up with what you need.
    tulsa america
    2,686
    phillips and payne havent figured it out sounds like another sceme for GRT to make money
    Quote Originally Posted by powerslide View Post
    Yet Hughes and Gustin sure have..... Grabo was on a lift arm in Vegas...... I would say it works in the correct hands......
