Pinion seal
Looking for a part number for a pinion seal in a PPM pinion mount.Ours got tore up and cant read the number on it.
Go Pa Racers............
If you're talking about the actual seal that goes around the pinion shaft, it is PPM0330. If you're talking about the thin rubber o-ring, that is PPM0320.
http://www.ppmracingproducts.com/sho...hp?cPath=31_53
