Sell out
2002 haulmark edge 34ft gn, 1ft extra height, ac, 26ft awning, gen. compartment, 4 110 lights 110 outlets, air throughtout 50amp breaker box.
2004 lightning 08 updates 9in swingarm swingarm brackets for 4bar less than 30 nights on car. Thousands in spares.
406 chevy alittle under 700hp lunati interals, afr heads, kse serpentine pulley system, msd, champ pan. less than 10 laps since freshened.
brinn tranny less than 10 laps since rebuild along with tilton bellhousing, and coupler.
willys alky carb with willys bypass system.
Spare parts to many to list.
Email me at bsoftail99@aol.com for ? and prices. car sells first
whats the prices on your items
All depends on what you want to buy. Single items or the whole package.
pics sent and pms answered
car and spare parts need to go make offer
Car needs to go. Make an offer. Here is a list of the spares for the car. Here is most of everthing I got probably overlooked some stuff.
> 2 5x5 beaddlocks with tires areo
> 3 5x5 non beadlocks with tires areo they are either 2 or 3 inch offset for both bead and nonbead
>1 barry grant fuel bypass
> 1 rf upper with ball joint new
> 1 lf upper with ball joint new
> 3 new ball joint
> 1 pitman arm
> 3 center links steering section
> 2 bilstien shocks 1090
> 1 bilstien 6060
> 2 upper spring buckets
> 21 qt. valvoline racing oil 20 50w
>1 afco nib 5x9.5 650lb spring
>1 procam rebuildable 15lb fuel pump
> 4 fram hp4 oil filters nib
> 2 outerwears shield breather covers 1 new 1 used
> 1 5x5 rim
>3 fuel jugs
>1 fuel funnel
> 5 axels 31 spline 28.25 32 33 28.5 didnt measure the 5th one
> 2 new rear bumpers
> 1 new front bumper
> 1 new rear tail support
> 1 23x19 griffin rad. used
> 1 21x19 thru cool rad. used
> 3 complete 9in center sections 5.67 5.00 5.43
> 2 ring and pinion in box 5.39 4.57
> 1 5lb fire bottel still charged
> 1 4 guage panel lonacre also with killswitch, start button
> 1 new throttle petal side mount
> 1 new 2 handle shifter with lock
> 1 coleman quicksteer with both 2to1 and 2to1.5 gears
> 1 dui chevy dist. just rebuilt
> 1 steering wheel splined release
> 1 steering shaft with 2 ujoints
> 1 5 point harness rjs used
> 2 drive shafts 30.5 33.5
> 3 tubular upper
> 2 9in carrier section
>2 panhard brackets for 9in
> 2 5x5 drive flanges
> 1 power steering tank with hoses
> 1 wilwood reverse mount petal assembly
> 17 swedge tubes with heim joints
>1 11" jack bolt
> 3 8" jack bolt
> 1 mid mount motor plate
> springs
>>>>>>>> 5.5 x 9.5
> 3 1100lb
>1 850
>1 650
> 1 750
> 1 700
> 1 900
> 1 800
> 5x11
> 1 225
> 2 500
> 1 250
> 1 200
> 5x13
> 2 150
> 1 300 new
> 1 400
> couple of others with no # markings
numerous other parts like rearend brakets, swingarms, rotors pad calipers, shocks, fuel line and filters, and a few crates full of stuff that I didnt go through. I'm sure I missed some other stuff. Plus all the things for the car itself headers, driveshaft, etc.
how much for the brinn trans ?
could i get prices. individual thanks
car and spares package deal. make offer
Motor SOLD!
Car and spares need to go make offer.
How much for the 5.67 gear
how much for your trailer?
Call me when you can, I'm interested in car and parts. 513 236 0118 what part of country do you live in also?
