Results 1 to 3 of 3
Thread: v belts
    Dec 2007
    116
    Default v belts
    How can a racer measure pulleys to obtain proper belt length? we are using v belt pulleys. One around w.p. to crank and another around crank, p.s., and w.p.Our previous setup was 30% reduction. We have a new w.p. pulley coming which will put us at 12% reduction and there is not a kit for this. I was thinking maybe a flat vinyl tape around the pulleys,as ive read the v belts need to be flush with the pulleys or sitting a little out of the v in the pulley. This is so the belts dont hit the bottom ot the pulley at rpm.
    Jan 2008
    995
    Tape and string
    Nov 2009
    Glennville, GA
    745
    Yeah we use string as well. I try and find a string or rope that fits in the bottom of the pulley, my alternator has a small landing in the bottom of the pulley. Then they just use that belt measuring tool they have and the rope fits in there just like on the motor.
    I get my belts at the local parts store. BS with them a little about the racecar and they usually never have a problem with me buying a few sizes and bringing back the ones I don't need.
    Crew Chief "Tip of the day":
