Tube lowers for metric?
Who makes the best,do they even make um?
I would try ubmachine or out pace. Poske sells both of them
Small metric of large metric like impala???
We produce and sell UMP certified tubular lower control arms to fit metric frames. They will fit small metric and Impala frames with the appropriate spacer kits.
These lowers give the widest track available (7" wider than stock metric or 3" wider than a metric with Nova lowers.
They are patterned after the 70-81 Camaro left side and Ford LTD Crown Vic right side. They use a screw in balljoint and have the spring helix built into the lower spring mount so the spring can be installed right side up.
They come powder coated satin black. $189.99 each and include the UMP series approval sticker.
Spacer kits are $14.99 per control arm.
Does these change the wheel base and if so how much?
Ruhlman Race Cars
These will increase the wheelbase compared to a stock metric lower by 1" over stock.
On a big metric/ Impala/ Camaro, the wheelbase will remain the same as stock.
