Misc. Dirt Late Model Parts For Sale
-Ohlins LMJ Set #7 valving four corner shocks-$1400 (used one season)
-Ohlins dummy shock, "LR clamp" valving-$400 (used two times)
-Winters Quickchange Sprint Center Rear End, aluminum tubes, heat treated lower shaft, anti heat black coating, new rear gear cover, used two seasons-$700
-Longacre turn plates, like new-$500, Longacre rear leveling blocks-$100
-Rocket frame shock bottle mounts, total of four-$15 each
-Afco 5lb take up springs with Afco slider, one new-$45, two used-$30 each
-AEM dryflow air filters, 14"x5", brand new, total of two, $40 each
-PRC Single Pass Radiator, 27 1/2"x19", very good condition, used one season-$120
-PRC Double Pass Oil Cooler, 16 1/2"x14 1/2", oil temp sesor fitting, #12 an inlet and outlet fittings, very good condition, used one season-$150
-Longacre 17" steering wheel, used five times-$45
-CV water neck riser-$20
-Rocket throttle pedal-$15
-Turbostart 16v battery, has 90% cranking power of new, would work great turning any motor under 14:1 compression-$40
-E-mail me at dboyer156@yahoo.com or look on racingjunk.com for photos of all these parts
Also for sale:
-Dry sump oil tank access panel and fuel cell fill spout access panel, both freshly powdercotaed black-$20 each
-Rocket motor plate, no cracks-$20
ttttttttttttttttttttttttt
Ohlins set #8 four corner shocks and #8 dummy shock sold, set #7 four corner shocks and clamp dummy shock still available.
ttttttttttttttttttttttttttttop
AEM air filters and shock bottle brackets sold.
Ohlins set #7 four corner shocks and two used take up springs sold. Dummy shock valved in clamp still available.
Three brand new front bumpers for sale also, $100 each. Email me for photos at dboyer156@yahoo.com
water neck
Can you post a pic of the water neck? thanks
I will email you the pics.
i was very happy with the springs
