Results 1 to 7 of 7
Thread: e85 vs gas
    Aug 2007
    167
    Default e85 vs gas
    For you guys on e85 what is the difference in consumption for a weekly show. I'm on gas now and a 10 lap heat and 20 lap feature I burn about 10 gallons. What would the consumption be on e85. Also do you have to change jets as often as you do with alcohol?
    Sep 2009
    23
    Is there any hp gains running e85
    for me I am in the limited modified class.
    2bbl 10.0 -1 355 engine class
    If so what changes do I need to do to run it. Been hearing alot about this lately and wanted to know more about it.
    Sep 2007
    473
    Quote Originally Posted by BW51 View Post
    i was told by a reliable source that theres no real hp gains but the torque gain on his motor was 15 over gas
    Feb 2009
    585
    response is better and pulls all the way down the chutes on e-85
    Sep 2008
    in the fast lane
    390
    Is anyone running 13.1 comp with E-85? We run in in a Crate and its been great. Its spose to have a 105 octane? Should be good for Hi comp engines!Anyone know for sure.
    BUSTING OURS TO KICK YOURS
    Jun 2007
    1,047
    Works great with the right equipment, and you'll want to check your fuel if you're not mixing your own.
    Jun 2007
    1,047
    From the gas station, 84-87% tested with the test kit.
