Solid Cam choice for Steel motor
Starting my first season in a late model. Will be running mostly open style shows, weight break for steel motors. Some local tracks also.
I have a steel head 355, budget is probably going to restrict me to a solid cam this season, and then upgrade to a roller next year. Looking for a good driveable solid cam.
Anyone have any suggestions?
Thanks!
A bit more info is needed to spec a cam, compression ratio, carb, heads, rpm you want to turn, etc. etc...
Josh K.
355 cubic inch
10.5 - 1 comp. ratio
Dart Iron Eagle Heads - 215cc runners
Super Hurricane Intake
750 cfm Holley double pumper carb
looking for 7000-7400 rpm
Anything else....just ask.
Thanks
Dur @ .050 254/258 106lc install at 101icl should be close Needs alot more compression and camshaft to really be a runner, but this should be very driveable
Josh K.
