Results 1 to 8 of 8
Thread: radiator
    Jul 2007
    259
    Default radiator
    how are the late models mounting there radiators and where do u get the long springs. some pics would help also.
    Nov 2009
    Glennville, GA
    745
    Mine just sits in saddles on the bottom. Here is a link for all the radiator hold down parts.
    http://pitstopusa.com/c-134707-cooli...-brackets.html
    Crew Chief "Tip of the day":
    Jul 2007
    259
    any pics anyone
    Feb 2008
    colchester il.
    2,172
    it's not easy to post photos anymore and most like me don't want to screw with it now.
    You can get the long springs from your local big truck supply store. Throttle return springs for a old International work just fine
    Use threaded rod instead of the long springs. On a rough track the rad will move around with the springs. My friend had springs and the fan went through the rad because of the springs.
    Dec 2010
    Montrose, PA
    27
    1/4 threaded rod works fine.
    This is my first year racing and my first time putting a late model together, I have a 05 rayburn and I used 2"x14"x1/8" aluminum flat bar for my straps to support the top of my radiator (I bought a 3 foot stick of it at tractor supply co. for like $12)...I found a peice of aluminum channel that was wide and long enough to sit inside of the top part of my radiator and I riveted the straps to the radiator, leaving around an inch or so hanging in front of my radiator so i could have somthing to hook my springs into...as far as the springs go, I found some at my local parts store, I know advance auto parts has like a 6 pack of those long springs for like $8. make sure you put around the same amount of tension on both springs. Hope this helps!
