ford 9 gearing help
I need help with gearing for a street stock on a 5/8 mile track
I would ask other racers there, way too many variables for a guy on here to guess..
tire roll out, rpm desired, cubic inch etc.
ball park is 5.67's or 5.83's..i run a big half mile almost a 5/8 and i turn 6500 with a 358, 3400lb car. I went to 67's late last year, got the motor down in the tq range more.
Just playin' in the clay
I'm run a 358 ci, 3000 lbs with 15x10 wheel
Just making sure it's not a typo, 5\8 track not a 3\8 ???? That's a huge track !!!
Central IL Bert Transmission Rebuilder
Brian (217)201-3640
somewhere between 4.56 and 6.00
Selinsgrove Pa. Pro Stocks mostly run 5.43. It's a BIG half mile, (actually closer to 5/8) 355 motor 2bbl 8 inch tire
Golden Isles was an oil based 5/8th's back in the day, took around a 5.13. When they put clay on it, went to a 5.67.
Gill T. Azell
yeah the track i'm running at is bedford speedway in PA. I'm going to tired 5.67 the first nite
@spy see you the 15th! Ive heard of guys running anywhere from 5.67's to 6.20's at bedford, im sticking to my 67's.
If you need more gear let me know.
I have a 9" 3rd member built by JR Motorsports. It has a Ford case, Motive Light Weight 6.00 gear, Ultra-Light Weight Full 31 spline spool, New Timkin bearings with solid spacer (not crush sleave) New Short-Wide yoke, bought wrong gear, only 6 races on gear, paid $680 shipped. Sell for $450 shipped in JAZ tote to your door.
Brian (217)201-3640
We run 5.83's at Bedford, turn around 6,900rpm with 90-92" rollout tires. (358 ci)
Josh K.
