Results 1 to 6 of 6
Thread: 4 link setups
    Apr 2008
    virginia
    195
    Default 4 link setups
    Was doing some reading and seen where integra said that you can clamp your lr front shock on a clamp and leave you other shock behind with the spring on it and run it like that for real slick conditions?? Is this the same as running clamped with the shock with a spring on it in front??
    787
    Shock and spring in rear and just shock only on clamp in ft. So when axle rotates whelp left car on lr
    When it slick`s over real good,i have mine clamped up with 200 psi in the shock,work`s good
    Where can I look to see a pic of the clamp bracket??
    Dakota, IL
    3,594
    Its an excellent set-up. I ran it with alot of success. I've got a few nice used clamp brackets left if your needing one. Call me 815-990-8865
    Jun 2007
    OZ
    82
    What valving to you guys typically run when you use this setup, for both the shock on the clamp and with the spring behind?
    Would a 7-2 in front and 5-3 behind be too aggressive?
