Results 1 to 11 of 11
    Jan 2010
    WV
    195
    Cool setup from tacky to dry track
    I would like to leave my dry setup shocks on all the time be couse the track dnt take long to dry out.. So sif I leave my dry setup shocks on all the time What else can I change on the car at the start of the nite besides the shocks from tacky to dry.... Thanks for any info.......
    May 2010
    632
    Wheel offset
    Open the wheel base up on the right side.
    Jan 2010
    WV
    195
    Cool
    Ok thank u for the info.. What offset should I change just the rr or what??
    May 2008
    574
    I used to do the same thing leaving my shocks on.
    I would start the heats with 1/2 fuel / a 3" on the LR, and 3" on the RR.
    When the track slicked off I would run full fuel and a 2" on LR with a 1" spacer or a 4" on the RR.
    You can always move the LU bar up on the chassis and the RU down as well.
    Also drop the rear stagger to 0 when it gets slick.
    It all depends on what your car needs in the end.
    Jan 2010
    WV
    195
    Cool
    ok thank u but I cant lower any bars .. Its a leafspring modified with stacked leafs.. Thanks
    When it's tacky, try a 3" RF wheel and 2" LF and then switch them when it turns slick. Also, you could try a little more rear stagger when tacky, then take it out when slick.
    Jan 2008
    195
    The easiest thing to do would be 3 wheel brakes in the tacky, 4 wheel in the slick rear to front or until the car comes to you.
    Jan 2010
    WV
    195
    Smile
    Thanks for the info.. I got another ? should I be scaling the car with driver or without driver.. multi leafspring mod... Thanks again for the info....
  10. #10
    Jan 2008
    195
    At first I would do both. Make notes of the difference in the #'s with you in the car verses out. After that you should have a good idea where you should be. P.S. unhook your shocks...
  11. #11
    Jan 2010
    WV
    195
    Cool
    Thanks for the info....I really need to unhook my shocks becouse they are not gas shocks??
