Winters Quick Change complete, fabricated spindals, wide 5 front hubs.
Have a winters quick change, out of an older late model. Has willwood wide 5 hubs, aluminum calipers (willwood), aluminum case, rotors have some surface rust, but nothing bad. Has all gears/axles, has leaf spring mounts, but could easily be removed for whatever suspension set up you want. no idea what gear ratio is in it, ran on dirt. Priced them on here anywhere from 600-1400...asking $650 for COMPLETE rear end...ready for your mounts and go, will consider reasonable offers. has 2 older wide 5 steel wheels on it, would clean up good, if you dont want just leave here.
Also have a set of wide 5 front hubs, fabricated spindles, and what appear to be camaro/nova control arms. Same aluminum calipers as rear. Cant find anything to price them against, so make me a reasonable offer! same with the wheels as the rear end.
Send me your best offer, call at 620 544 6961
ment to post this in the for sale sections...sorry all.
