the mono ball bearing type is the best i've used. second choice is the elastomer ones made by seals-it, third would be oem. 4th would be urethane, distant fifth would be the super soft ones (medieval, speedway, x factor)
Luke do the seals it last? Where are you getting them?
I want your pulleys on ebay pm me a price so you can end the auction and mail them to me! postal theyll fit in the small flat rate box or flat rate envelope you can print a label off paypal!
if you can run bearing type i would run them in all 8. running rubber up top does very little to cushion torque. its more of an advantage to have the suspension moving free.
