this is what have to run need help on shock's and spring's''''' the coil over eliminator's right is in front of rear end left is behind rear end like a shaw. car and dirve 2550 rule / bird cage's must be welded solid , 11. REAR SUSPENSION: All components must be steel. All mounts and brackets must be welded or bolted solid. Coil springs must remain vertical. Coil-over eliminators or steel spring sliders allowed. Nothing may be mounted on lower control arms. Must utilize one of the following designs:
(A) Aftermarket three link design requirements: Must use minimum 16 inch lower control arms equal length left to right. 1/2inch tolerance Must use one upper control arm (pull bar) with biscuit (Maximum 3 biscuits 2 ¼ inch in diameter) located at top center of rear end housing (1-inch tolerance) Must use minimum 23 inch pan hard bar located behind rear end housing. 9. SHOCKS: One steel, nonadjustable, non rebuild able sealed unaltered shock per wheel. No bumpers or stops. No threaded body, front coil-over, air, or remote reservoir shocks. No Schrader or bladder type valve allowed. Front half may be shielded
