Results 1 to 5 of 5
Thread: any sugestions
    Mar 2009
    McWillie,ok.
    59
    Default any sugestions
    I built a 95 mustang mini stock,swapped the rearend out for the one we had under the old 76 mustang,because i had alot of 8" gears.now i would like to change the front to 4 hole instead of 5,so all my wheels work.anybody ever try to put 87-88 thunderbird turbo coupe rotors on the mustang spindle.from what i've found it looks like the 87-90 mustang spindles are the same,but i don't know if the 94-04 mustangs are different.anyway if you have any sugestions they would be greatly appreciated.
    Aug 2007
    Fremont, CA
    190
    evr think bout just seein if they fit n-e-way?
    Jul 2007
    199
    Same knuckle 87 88 t bird as the 87-93 mustang
    Mar 2009
    McWillie,ok.
    59
    yeah i thought about it,but i have to buy some to try,and thought someone might be able to save me from buying several pair to find ones that work.are the 87-93 spindles the same as 94-04 or will they fit on the 95.
    Jul 2007
    199
    Never tried just changing the rotors to different spindles. I have had customers in buying our 97 98 knuckles to put on there fox body mustangs, direct bolt in. You might try calling a parts house to see if the bearings are the same for 87-93 and 95. Knuckles around here are going for only 20.00 each for the 87-93s. Cheep and no worries.
