Results 1 to 5 of 5
    Nov 2008
    359
    Default Rocket header LS
    we have an 01 rocket, black front. LF UCA is inboard. Problem is we dont have enough room between the cross shaft and the engine to get a header in there. Is there a specific header for the LS on a Rocket? Or do we need to just run the engine to the right in the second set of holes?
    Nov 2008
    359
    32 views a no one has a rocket? lol
    look in the schoenfeld catalog,rocket headers are different than others
    Schoenfelds have the most clearance, but you will still have to clearance the tube with a hammer. Your other option is use the adjustable midplate and raise the engine up a half inch. Your final option would be to run the engine to the right. I've ran the shoenfelds with no issue for 3 years. If you call Rocket they will tell you to raise the engine.
    Nov 2008
    359
    yeah I believe thats what we are going to do, we have the multi position plate from rocket and it will help out with the rules we run under as well. Thanks Guys!
