Nova Lowers - Lower Control Arm Bolts
I noticed that the nova lowers take a 1/2 bolt through the bushings. Is everybody still using the metric bolts that that are a hair smaller then the 1/2 bolts?
Drill thru the lower control arm mounts with a long 17/32 " bit.They need to all be in line.You will be suprised how far most frames are misaligned.Drilling thru them should help line them up.
