Someone correct me if I'm wrong but I've always been told no more then 10*, might be safe to 15* but when you get it at too much of an angle it will change the ratio of the shock due too much angle.
15deg is common, you talking just shock or coilover too, if coilover that's when you
Need to pay attention to how far you lay it in or you will soften your bump travel rate but again 15 deg is common.
