Results 1 to 7 of 7
    Default Setting up a car running a truetrack, and driving style.
    This year we decided to try a eaton truetrack differential. How much differently is the car going to have to be setup and how will I have to adjust my driving style? The track is always heavy in the heats and dryslick in the feature with the line being all the way down against the uke tires. In the feature if you can stay all the way on the bottom and stick your line perfect each time like an asphalt track, you're unbeatable. I figure having the advantage of an unlocked rear end would be great in the features where a locked rear gives you a push on the bottom if you drive in too hard. Any thoughts or opinions?
    Feb 2008
    Barrington il.
    881
    Every one tries this at some point in thier career. It will loosen the car period! Just make sure you can lock it back up! After a few nights you will lock it and never go back! This is not asphalt racing. You can post next season that I was on the money! I will look for the thing for sale on another part of this board. Really though, I don't think you should do it. If you do get it to work, you are a better man than I! Good luck with it though.
    553
    How does a limited slip work?
    Would a gleason type work? (diamond track or DPI platinum?, Locker with leftside lockup?)
    Auburn, IL
    2,854
    If anyone is looking for a DPI Platinum...contact me...sell half the cost of new! 31 spline for ford 9 inch.
    Jul 2007
    3,224
    dont drive in too hard on the bottom and you wont have a push.
    I tried a detroit locker when I ran pavement... I was the track record holder timing in and broke my own record for 3 years. I timed in changed 3rd and did it again and it wasnt any faster... in traffic it sucked, the locking and unlocking wasnt smooth.
    maybe a tru track is better I dont know. But I do know I have no need for one on dirt...
    Oct 2007
    152
    Quote Originally Posted by Graff Spee View Post
    Moyer has run one for YEARS. Working on a UMP modified right now tring to get the setup correct. GRAFF SPEE is correct it will make the car loose. stagger will not be you friend with it. It works for some and not for others. I hope it works for you!
    553
    yeah, little or no stagger. Thats the point.
