Results 1 to 3 of 3
    Mar 2008
    Cartersville,GA
    493
    Default Skid Plate for rack and pinion
    What would be the best way to fabricate one? Should I use aluminum tread plate?
    Feb 2008
    colchester il.
    2,172
    when we made ours we just cut a 14'' by 20'' of standard body aluminum folded that in half making a 14''x 10. then we put 3 to 4 brakes in it to get it to wrapped up in front of the rack then just drilled and bolted it the the bottum of the crossmember.
    Mar 2010
    272
    avoid 6061-T6 alum. it's common in tread plate. good for strength but doesn't bend easily.
