2.0 ford pinto engine question
Was wondering if the 2.0 early ford engine is a internal balanced engine, or if the balance is done at the flywheel? I had a alumn. flywheel and a stock type pressure plate that I have had balanced seperate and together as a unit, just wanted to be sure of the balance issue before installation. Thanks in advance.
'71-'74 2.0L Ford is internal balance. No bobweights on the rod journals when balancing. -Dave-
