Results 1 to 5 of 5
Thread: loose entry
    Jul 2007
    259
    Default loose entry
    car is loose on entry off the throttle, feels like the rr is just sliding on top of track.
    car is leaf spring.
    whats the best way to load the rr more on entry so it will tighten up gettin in and still come off good
    Dec 2007
    1,039
    Move RR tire/wheel In
    Lower RR air psi
    Move ballast/fuel cell up and/or to the right
    Stiffen RR spring, may loosen exit
    Run less LR bite
    Taller lowering blocks
    Less compression in RR shock to quicken weight transfer
    Gill T. Azell
    Aug 2007
    184
    Default Loose
    Also stiffen LF or weaken RF
    Feb 2008
    Barrington il.
    881
    Pull in rt. rear wheel or move out lft. rear wheel. Soften rt. rear spring. Check your shock travel indicaters. You don't want more than 4 inches of wheel travel on rt. rear. If you have more than that you are most likley to soft on rt. rear spring. Yopu can also move rt. front wheel out to tighten on entry.
    May 2010
    632
    Don't let up on the gas so much, or turn up the idle.
