If you can't us a long yoke in a std. bert then how far in do the splines actually go that causes the long yoke to bottom out? Or is it just hitting the bushing? Also if a 6inch shaft on the long yoke wont work with the std bert then would a 5 1/2 work?
The yoke slides in about 4 inches before it bottoms out in the tailhousing? But with the driveshaft hooked up its only in the housing about 2inches. Basically what happened is i had a 4 inch shaft on the yoke i was using and it caused a vibration since it was barley in the housing. So i got a yoke with a 5 1/2 shaft.
