take 40% off these remaining parts available
new updated list of parts still for sale!!!.40% now thru may7,2011
HERE IS A LIST OF PARTS STILL AVAILABLE AS OF TODAY.
SBC 355 BLOCK WITH STOCK TYPE PISTONS AND RODS. HAS CRANK BUT NEED REGROUND. $300
SBC 400 BLOCK BARE 817 CASTING PUNCHED .040 OVER, $500 OBO
3 SPEED SAGINAW TRANNY WITH STOCK BELLHOUSING $350 OBO
VALVE TRAIN COMPONENTS:
COMP CAMS ALUMINUM STUD GIRDLES $25
16 COMP CAMS VALVE SPRINGS DOUBLE SPRINGS BIG DIAMETER .650 LIFT $25
16 POLY LOCKS @25
16SPRING RETAINERS FOR ABOVE SPRINGS $10
16 COMP CAMS ALUMINUM FULL ROLLER ROCKERS 1.5 RATIO $100
16 COMP CAMS 7372 MAGNUM PUSH RODS $25
1 ALLSTAR POWERSTEERING PUMP WITH RESEVOIR AND HOSES $225
1 UNKNOWN HV POWERSTEERING PUMP WITH RESEVOIR AND HOSES $175
CARB COMPONENTS:
1 750 CFM ALKY RACE DEMON CARB WITH 850 BASE PLATE $400
1 CARB COVERS $5 EACH
1 PROCAM ALKY FUEL PUMP NEW IN BOX $75
1 EDELBROCH HV FUEL PUMP 120GPM BARELY USED WITH BRAIDED FUEL LINES $50
1 ALKY FUEL REGULATER WITH RETURN FUEL OPTION ADJUSTABLE $30
RADIATOR HOSES: THESE ARE THE REINFORCED WITH WIRE
1 20" UPPER $5
1 25" UPPER $5
1 16" BOTTOM $5
1 23" BOTTOM $5
1 ALUMINUM RADIATOR RESTRICTOR 5/8 FLOW HOLE $5
BRAKE COMPONENTS:
1 WILWOOD CLUTCH PEDAL AND M/C SWING MOUNT $50
1 AFCO BRAKE M/C $25
1 WILWOOD BRAKE M/C $25
1 WILWOOD BRAKE PEDAL W/2 M/C FLOOR MOUNT $75
1 ALLSTAR FUEL PEDAL $10
WHEEL AND TIRE COMBOS: $50/COMBO
3 BEADLOCK 4.75 BOLT PATTERN 15X8
6 NON BEADLOCK 4.75 BOLT PATTERN 15X8
TIRES ARE ALL HOOSIER EMOD A TYPE
WHEEL SPACERS: $5/EACH
2 1"
1 3/4"
LEAD WEIGHT: $1/LB
1 PIECE @ 24.6 LBS
1 PC @23.2 LBS
1 PC @25.8 LBS
1 PC @72 LBS
1 PC @37.4 LBS
1 PC @25.4 LBS
2 PC @10 LBS STEEL
COIL SPRINGS: $25/SPRING
AFCO SPRINGS
175,200,225,250,300
FRONT SPRINGS 1000,1100 LB
HEADERS:
1 PAIR SCHOENFIELD STOCK TYPE FITS MONTE AND CAMERO $50
1 PAIR HOLLEY PERFORMANCE STOCK STYLE FITS MONTE AND CAMERO $75
DRIVESHAFTS: $40/SHAFT
1-52" X 2"
THESE HAVE SLIP YOKES FOR CHEVY
MISC:
1- MONTE CARLO STEERING BOX WITH SHAFT AND UJOINT $50
2 -MONTE CARLO SPINDLES $50/PAIR
1- SET UB MACHINE UPPER -arms FITS MONTE 8" AND 8.5" $40/SET
1- SET REAR MOTOR MOUNTS NEW FOR CHEVY $20
1- PRC INTAKE MOUNT LIFTING PLATE $10
1- 4BLADE 32 DEG PITCH FAN BLADE 17" $20
1- HOWE QUICKSTEER 2:1 $40
1- CAN MASTER BEAD SEALER $5
1 ALLSTAR WATERPUMP HV $40
1- CORVETTE HV WATER PUMP NEW NEVER USED $25
3 STEEL GM FLYWHEELS 153T $5/EACH
1-AUTOMETER OIL FILLED OIL PRESSURE GUAGE $25
ENGINE COMPONENTS OR ACCESORIES:
1-4.00 ALUMINUM RING COMPRESSOR $8
1-4.155 ALUMINUM RING COMPRESSOR $8
1-MELLING HV55 OIL PUMP NEW $20
SAFETY GEAR:
2 LAYER FINISH LINE RACING FIRE SUIT XL JACKET AND XL PANTS $100
1 PAIR RJS RACING FIRE SAFE SHOES SIZE 13 $40
ALL SAFETY GEAR IS BLUE IN EXCELLENT SHAPE
THIS CONCLUDES THE LIST FOR NOW PRICES WILL BE UPDATED TOMORROW.. THANKS FOR LOOKING AND HOPE TO SELL U MANY ITEMS...
ALL STUFF IS FOR SALE AND WILL SHIP MOST SHIPPABLE ITEMS..
PACKAGE DEAL AVAILABLE JUST LET ME KNOW WHAT YOUR INTERESTED IN AND I WILL DO MY BEST TO MAKE A MULTIPLE ITEM DEAL... SHIPPING WILL BE AT BUYERS EXPENSE FROM ZIP CODE 62458
Last edited by Erichofer77; 05-01-2011 at 04:37 PM. Reason: update items available
st elmo il 62458
