slick track gears
im kind of confused on what gears i need to run. when the track slicks off to blowing dust i know there is no setup in the world that you will be able to run wide open off the corners. we have been taking gear out to help keep from blowing the tires off down the straights. is there a point where that will start hurting us or should i look at maybe slowing the 4 barrel from kicking in so early?? i could only run about 1/2 throttle befor it would spin the tires down the straights?? thank you for any help.
