GN hub. Longer stud??
Does anyone make a longer screw in stud for a GN hub? I would like to run a 1/2 inch wheel spacer but the threads are only an 1 1/4" long. Doesn't leave many threads for the nut.
Thanks
Speedway motors have a few different styles depending on if you have screw in or press-in. The screw-in type only look to be 1.25" like you said. One option would be to unscrew the studs and drill out the treads and install the press-in style studs.
