Results 1 to 4 of 4
Thread: pulley question
    Default pulley question
    which would best a reduction set or a 1:1 set on a sbc turning 6500 to 7000? Thanks.
    Aug 2009
    668
    depends on the temp you are running. if youre running a little warmer than you want you might want to get a set of reduction pulleys or go to a double pass radiator or both. in our LM we run a set of 1:1 with a double pass and we stay right around the 190 mark most nights but it will start to get closer to 200-215 on the hottest nights when the track is really hooked up.
    Feb 2008
    Barrington il.
    881
    Usually a 20 percent under drive works well.
    thanks guys for the info.
