Results 1 to 7 of 7
Thread: J bar rake?
    May 2011
    167
    Default J bar rake?
    How much rake do you want typically in a modified? 4 bar 4 bar. And what does raising it up and down on the frame side do?
    Muscatine, IA
    189
    Starting Point:
    Start with pinion end at:
    Ford 9" - Center Line of Pinion
    QC - 1 1/4" to 1 1/2" above pinion center line.
    Then set rake so left hand frame end is 7" higher than pinion end. Measure from center of attaching bolt to center of attaching bolt.
    Adjust as needed from there.
    Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
    Feb 2008
    Barrington il.
    881
    Yup!! Listen to big blue!
    raise it for less body roll or lower it for more body roll
    Nov 2010
    Lock Haven, Pa
    664
    Raise it on Frame side for less body roll??
    Quote Originally Posted by dirttrackrocker View Post
    Yup. Acts like a kickstand on a bicycle with more angle.
    Feb 2010
    24
    Quote Originally Posted by 28m View Post
    I am not seeing how this works......can you give some more details on this???
