Results 1 to 2 of 2
    Default Roller lifters with a small base circle cam
    I have a sbc block that is right side dipstick, 80 to 86. It was a factory roller block. My question is what roller lifters would I need to use with a small base circle cam in this block.I am building a 383 with eagle H beam rods and thats why I am going with the small basecircle cam.I want to run solid rollers. Thanks for any help.
    Sep 2009
    371
    You are going to have to run a .300 tall lifter. Make sure the oil band on the lifter doesn't come out of the lifter bore on the bottom.
