Results 1 to 6 of 6
Thread: any ideas,
    central IL
    112
    Default any ideas,
    my motor keeps dyeing. it will sit and idle just fine, sounds real responsive. runs fine untill i drive it and smash the gas. seems like with the secondary kicks in on the carb it dies. it is fine as long as im on the gas but the minute i lift the motor shuts down. its a 383 (500 hp) with a 750 ct quick fuel carb. any help would be great.
    Sep 2007
    202
    check fuel pressure a nd change carb.. or take carb apart and blow air thre EVERY whole you fine..
    Oct 2007
    904
    make sure your fuel filter is flowing the right way, check the pick up in the cell too... something isnt flowing enough fuel and the engine is running off the fuel in the bowls, but the fuel system isnt filling the bowls back up quick enough
    Jul 2007
    3,224
    sounds like your saying it dies when you get off then back on the gas? that would be your accelerator pumps, the butterflies open quick and let in a lot of air you need the added fuel of the acc pump or pumps to feed the extra fuel at that time!
    Jun 2011
    11
    are you running foam in your fuel cell some times it gets old and starts comming apart and will clog
    Jul 2011
    4
    did you mean dying? check your engine or accelerator pump.
