how much bite do you run in a mod chassis is a d&m 4 link on dry slicks
Try between 30-80 with driver in car. Some run lower, some higher. What are you trying to get the car to do? Good luck.
Originally Posted by washeduptoo Try between 30-80 with driver in car. Some run lower, some higher. What are you trying to get the car to do? Good luck. If by bite you are meaning the diff between left and right rear wheel weight we have ran for 40LR to 10RR
Yes I meant lr wt above rr wt, that is why I put some run lower some higher. It all depends upon what car/driver need. Good luck.
Most chassis manufacturers say Start at 30#-40# without driver.
