mastersbilt genx ???????
If a person was to put a dummy shock on the left rear with gas where would he put it front or back?
MasterSbilt65
I haven't seen a dummy mono tube shock before. The dummy I use is an Afco 1390, twin tube shock. I use it basically as an eliminator, to hold the spring in the rear. "Traction shock" in the front.
I did run across an Ohlin's dummy shock somewhere for over $600! Can't quiet understand that one.
A working, non adjustable, STJ Ohlin goes for around $350.
Gill T. Azell
