I am not sure about Rayburns, I run a 2000 Warrior.
But with me in the car my LF is 85 pounds heavier than the RF. Generally this is the norm. The LR is always heavier than the RR (bite). So the LF will need to be heavier than the RF to keep he cross % in the ball park.
But there was a thread not to long ago about running the same weight across the front tires. And Rayburn was talked about. I am sure you could find it with a quick search. It was a good thread.
Crew Chief "Tip of the day":
