Setting lift bar on rocket
Just removed an off brand lift bar and replaced with a genuine Rocket lift bar assembly. Cannot get the lift bar level. I can get the proper pinion angle, but not having any luck getting below 2.5* of angle on the lift bar. I am using a digital angle finder placed on the lift bar. Is this the correct way? Any recomendations for measurements on the 6th coil assembly? This is on an 08 1 3/4" Rocket. Thanks in advance
