Results 1 to 8 of 8
Thread: Cooling issues
    Nov 2010
    20
    Default Cooling issues
    What would cause me to be pushing water out at 180 degrees? It keeps pushing water out till the water is too low and then it runs hot. It does the same thing every week. It shouldn't be pushing water no hotter than that so im wondering what would be causing it? Thanks in advance on any ideas.
    Auburn, IL
    2,854
    I would say head gasket as problem #1 or a faulty temp gauge which would bring other problems into question. What is the rating on the radiator cap?
    Nov 2010
    20
    28 to 32 lbs.
    Glasgow, Kentucky
    4,852
    Quote Originally Posted by dove14 View Post
    28 to 32 lbs.
    How old is the cap and has it been cooked? If it is over a year old or has been run hot I would replace it.
    Dec 2008
    1,238
    if gauge ant messin up,...head gasket or a crack....bare in mind,...water dont boil till 212 degrees.....
    Nov 2010
    20
    Thanks for all the ideas. I've tried 3 different gauges, and I've changed the radiator cap 3 times.
    Illinois
    3,165
    NAPA sells a unit that you remove the rad. cap and place this over the cap area and if it changes color it indicates combustion in the water. May save a tear down.
    Fought the same thing for about 2 weeks. Bad head.
    Nov 2010
    20
    Thanks alot. I'm willing to try anything now.
