wanted: 406
actually a 406 shortblock would work also,,, must be pretty fresh and be able to prove it,, 23 degree, would like something all i need to do is slap a pair of heads on it ,, thanks email me at 66vinylgraphics@gmail.com Thanks!
have a 377 sbc uses the 400 block 10 races on it will sale shortblock or whole motor solid roller cam engineblock is cheator one 2 freeze plugs eagle lightweight crank rods mahle pistons stepfs pan shortblock assembled make offer or with pro topline aluminum heads shaft rockers victor jr intake holley hp carb take 3700 with carb minus dist or 3500.00 for complete engine minus carb dist still in car can hear run engine made 622 horsepower on dyno i need a 358 max engine next year will take 2300.00 for assembled shortblock ty 757-374-3159
Found this on another site::::
406 scat crank, 6in hbeam rods, je pistons, comp roller cam and lifters, holley intake, dart iron eagle heads, ferrera valves, double springs, comp roller lifters, scorpion roller rockers, morroso water pump, very few laps since freshened
also have a short block 406 valves hit pistons, cylinder walls look good, dont know if its good or not,
620 gears full spool set up ready to go
moving and need to sell this stuff fast, $2000 is my absolute bottom dollar
Fred 501-860-2797
406
SBC 406, GM steel block, brodix 10x Alum heads that have been ported, Eagle forged crank & rods, Wiesco forged pistons, roller cam, wet sump motor, atl super damper, distibutor for msd, pulleys, fan, mechanical fuel pump for alky, holley HP alky carb, ready to drop in. 3 races since last freshen. Can be bought with or without carb.
This is my back-up motor, bought an aluminum motor last year.
Asking $5000 with carb and $4,500 without. Can hear run.
Have a 408 I am getting ready to assemble. 817 block. 2 bolt main, deck's been plugged, decked to 9", bored-honed w/torque plate to 4.165, oil pan rails clearanced. New external balance scat 9000 3.75 stroke crank, used 6" eagle H beam rods (8740 rod bolts), used JE 23 degree dome pistons, Clevite rod and main H bearings, ARP main studs, JE rings, cam bearings, freeze plugs.
Started to build this, customer changed his mind, wanted a 383 instead.
Call Jerry @ 319-930-0583
JD's Performance
13034 Hwy 99
Wapello, IA 52653
319-931-0677
