Results 1 to 6 of 6
    Jul 2011
    Podunk, Idaho
    35
    Question 2.3 EFI Intake gutting
    Anyone know how far the EFI Intake can be cut down into the runners before you hit the water jacket?
    under BIGDAN32's skin
    421
    a ton. and if you hit the jacket you can just TIG the hole or even jb weld it, or just block off the water port at the head and you won't have to worry at all. get a couple intakes and max out one until it's thru, then just back off the grinding, then you'll know the exact point of no return.
    Jul 2011
    Podunk, Idaho
    35
    Quote Originally Posted by pobort View Post
    I usually block off the water jacket anyways. I only have one to work with and was worried about going through the wall into the jacket and then having to figure out what to do next. Our rules say that we can cut the runners down up to an inch. So... hence the question.
    Dec 2010
    302
    thats making a turtle in top!!
    Jul 2011
    Podunk, Idaho
    35
    Quote Originally Posted by Dan32 View Post
    I was thinking about removing EVERYTHING down about 3/4". Starting the turtle at that point.
    Caution: I spin without warning.
    Jul 2007
    199
    More is always not better. I have one that was cut and flow tested. You can stop by sometime and see what mine looks like.
