9 inch gear question?
pinon turns 6 an 1/4 times to axles 1,...what gear is it???
6:25 if that is exact, probably a 6:20 or a 6:33 though.
It takes more time and you need someone to help slowly turn the tire but if you turn the tire (axle) 10 times and count the driveshaft turns it will be spot on. Will likely be 62 or 63 turns. Eric
SRXSRULE
thanks,..just what i needed to know!
Egoracing
as exact as it can be without degree wheels,...what i was thinking....6:20 as deep as i can go,...6:33 lil toooo deep!
looks like its a 6:33....
