RR Shock
If I have a RR shock on a coilover in front now and wanted to change that and put the shock behind and spring in front on a slider what would I have to do to the shock to make sure it stays the same. Right now the shock is a 3 on compression and 4 on rebound when we ran it in front. With this change anything else with the way the car is.
Also is it possible if I put a 3 on compression and 5 on rebound on the RR in the slick that the car might stay on the RR to much and loose traction because it wont allow the LR to work and trasfer weight.
