2009 Bob Pierce Modified Chassis #813
All new bolt-on parts. US Brake hubs & calipers (small piston on right front), AFCO springs (front & rear), UB upper with Howe ball joints, tubular lower with Howe ball joints, Coleman quick steer 2:1, Wilwood brake & clutch pedal with AFCO master cylinder. Used Winters quick change with new Winters hub & US Brake calipers. All new birdcage, lift arm, lift arm hold-over, lift arm & pull bar brackets. Bob Pierce pull bar with new HyperCoil spring, quick change filler can & hose, new 32 gallon teardrop fuel cell, fuel filter & bracket, with new fuel line & fittings. Longacre 3 gauge panel, starter panel and wiring kit, shifter & brake adjuster. Two sets of AFCO Bob Pierce shocks; one set for mud and one set for dry. Black frame, black decking, chrome driver compartment, black hood, nose, roof & side panel. Chevron Blue sides. This is a left-rear screw jack chassis. For more information call or text 309-830-3143 or email cdmnet@live.com. Asking $7500.
may take trade in, would like a passenger car,smaller please or tell me what you have.
How many nites on chassis ?
the chassic has 6 nites on it. call or text if you need any more infor. this car is in cental Illinois thank you
back to top///////////////////
