Leaning Hard On The Rev Chip?
Rev Limiter Blueprinting Get 400 rpm Back!
Do you always seem to be riding the Rev Limiter Chip?
If youre racing an MSDŽIgnition 6al, 6aln, 7al2 with an on board rev limiter or a MSDŽIgnition 8738 or MSDŽIgnition 8728 stand alone soft touch rev limiter. Youre giving up at least 175rpm while leaning on the limiter. And if you typically run in a field that is easily covered by hundredths of a second or less then you want to get that rev limiter blue printed to get access to ALL the allowable rpm by the One percent rule. To achieve the results needed, adjustments to the Rev Limiter circuit can be performed to get it into the very top end of the allowed One percent margin mandated by many sanctioning bodies. If your driver likes to lean on the Rev limiter during the race, it will allow them to get back an avg. of 200 or more useable rpm. It also raises the starting point of when the Rev Limiter circuit starts to kick in; most racers dont realize that the Rev Limiter circuit starts in 175 rpm lower than the RPM marked on the Rev chip. Another issue not commonly known, most current chips are running at least 109 rpm lower than the number marked on the Rev chip. So as a racer your giving up a lot of top end usable engine rpm during a race due to tolerances being to loose. If youre running a class that is very tight, you need to give the rev limiter the winning treatment. The total cost for the Blueprinting is $100.00 which includes return shipping. www.techwestracing.com
ep33510
704-995-4286
