street stock base set up
What would be a good base line setup for a metric street stock?
Cross
Left
Rear
Shocks and springs
Ride heights
Stagger
Camber and caster settings
This is for a rookie driver setup with just a few races under his belt somthing stable and easy to drive
A few rules are 3200 lbs stock frame and suspension no wieght jacks 8 inch wheel and hoosiers g60 tire
Track is large 3/8 mile mostly dry and dusty track big sweeping turns with slight bankings long striaghts
Like I said its for a good starting baseline for newer driver something stable
Thanks
