Results 1 to 2 of 2
    Sep 2009
    Indiana
    164
    Default Scrapping leafs: Need advice on next setup
    My current car is set up on leafs of which I want to scrap for another setup this winter. I know basically nothing about the 4 bar type stuff, but willing to learn. I'm planning to do the work myself on the switch, but need advice on how things should go together or where to look for info on mounting of brackets, placement of parts, angles, etc. Any help is highly appreciated.
    U can step on the brake
    U can step on the gas
    But step on ur crank
    UR gonna get passed!
    Feb 2008
    colchester il.
    2,172
    how wide is your frame just behind the seat were the 4 bar bracket need to go? some leaf cars are pretty wide and the causes problem when tring to switch over to 4 bars. also the rearend should be 59 to 60'' wide some leafs are 62'' wide. I could help just pm me your e-mail address and we can go from ther. I'll need wheel base and bar length you plan to run and what bird cages.I'll design it on autocad so you see whats needed before cutting anything apart.
