Results 1 to 8 of 8
Thread: Mod body help
    May 2011
    28
    Default Mod body help
    What is the best way to roll the lip on the wheel well to get rid of the sharp edge?
    Nov 2010
    Lock Haven, Pa
    664
    Quote Originally Posted by Racer7R View Post
    An easy edger. They are pretty expensive though. Don't be fooled by the little vice grip looking things you see people selling, they SUCK!!! The only way to get a good hem on a curved cut is an easy edger.
    Jun 2010
    Santa Land
    554
    I use a base ball bat. I take a pliers and curl the lip to where I want it at the top of the wheel well. Then I jack up the frame of the car and remove the spring. Lower the car and starting at the lip that you made with the pliers work either forward or back just rolling the bat along the top of the tire and the body.
    Oct 2008
    139
    I use linemans pliers and roll the entire wheel well about where I want it. Then I use a body hammer to smooth and reshape from underside of lip I just bent.
    Sep 2008
    431
    Take a pair of regular pliers and weld 1/4 or 1/8 round rod on just the width of the jaws. You can do 2 qtr. panels in 5 minutes.
    Jun 2007
    Whiteland Indiana
    2,714
    take a 2x2 or whatever, slice a notch in it about 2-3 inches deep and round one side, and use that. I think Allstar makes one but its a lot cheaper to make your own.
    ChrisRische4k@hotmail.com
    FaceBook: Christopher Anthony Rische
    Twitter: @realchrisrische
    " 'Eer Raid"
    The undisputed 2010 Fairbury Dash for Beer Track Champion.
    Apr 2011
    28
    SS Motorsports hit the nail on the head. We been doing it that way for years. Roll the front part out and from the joint of the door and quater back roll it under
    May 2011
    28
    Thanks for all the responses.
