350 race engines
One race built 350 with eagle bottom end and sealed power pistons, 010 block all good machine work by Jordans Performance, all std bearings and 030 over on bore, custom cut cam, edelbrock intake, vortec heads, roller rockers, screw in studs, alum valve covers, 8 quart racing pan, cloyes timing chain, this engine was built for a spare and
-only has 5 races on it since being built well over $5500 in it and the first $3500 takes it
2nd motor is short block with corvette crank and rods with trw pistons, .010 on mains and rods, 8 quart pan, comes with crane cam and lifters, timing chain all you need is heads intake and the motor will be complete $1200 takes it
http://www.racingjunk.com/Circle-Tra...Y-ENGINES.html
make me an offer great street engines or round track
