Results 1 to 7 of 7
Thread: Help
    Sep 2008
    108
    Default Help
    I have a 2.5 pro 4 motor that stutters and stumbles all of the time. It does it at low and high RMPS and it does it much worse under a load. We have changed the fuel system carb-hoses-filters-cell, wiring, distributor, lifters, valve springs, intake, head, and I am sure more that i am forgetting. Does anyone have any idea what we could be missing?
    Please let me Know what you thinks Thanks
    Aug 2007
    187
    Default Stumbles
    Have you changed the plugs? Had a motor that had the plugs fouled at one time and would never clear out. Put a new set of plugs in and ran great..
    Sep 2008
    108
    Yes we have we have tried diffrent heat plugs and gaps as well but thanks
    Colstrip,MT
    351
    Did you check you cam timing? Also Did you degree you cam?
    2,319
    compression check and compression on each cylinder?
    BUCKLE UP NOW, YA HEAR?
    Oct 2008
    Michigan
    102
    Ensure that you have a non-restrictive air filter system and that filter is not covering bowl vent. I have encounterd this problem on a 2.3 in the past. Chased my a** for awhile. Finally put it on the track without filter and concern was gone. Good luck.
    Sep 2008
    108
    alright guys I had to have the cam degree checked so it took me a few days but it was fine I also checked the air cleaner and compression and all of that was fine do u have any other ideas
